transamz9
Dec 22, 2013Explorer
racer4 wrote:
horseylady,
There are some upgrades available. They are expensive, but way less than buying a different truck.
You can look into R4Tech, Auto Flex and Kelderman Air Ride.
R4Tech link
Auto Flex Air Ride Suspension
Kelderman Air Ride 2003-2009 Dodge 2500/3500 2-Stage Rear Air Suspension
Kelderman Air Ride 2003+ Dodge 2500/3500 2-Stage Front Air Suspension
When I bought the Kelderman Air Ride for my truck I did not know it would lower the rear of the truck and reduce the rear suspension travel by about 2 1/2". I worked around that with a 2" lift block and pinion angle shims.
Kelderman has since changed their website and now reference "Stock Height". If you consider Kelderman, I suggest you verify if it will significantly change the available suspension travel.
The other two choices above became available after I bought.
The new Dodge trucks now have a factory option for air ride suspension upgrades. You can accomplish something similar with available aftermarket upgrades.
No more back pain for me after driving the truck.
Good luck.
I have this one and no loss of suspension travel.
AirBagit towing kit.
44,066 PostsLatest Activity: Apr 10, 2026
