jims1
Dec 22, 2013Explorer
Remove the seat from the truck, Flip over, undo the metal wire rack- cut the hog ring holders and remove foam. Add whatever foam you would like, I used a piece of high density oopen cell then a piece of memory type. Reassemble with new hog rings. Its easy to do, takes less than 15 minutes to remove and open up. The other idea is to find 2004 seats in the same color and bolt them in. Much more comfortable. $generations seats fir as well depending on the model.
I did this about 80k ago.
44,066 PostsLatest Activity: Apr 10, 2026
