noonenosthis1 wrote:
We currently have a TT but I've heard that a 5th is easier to tow.....we have a 2015 F350, single rear wheel, crew cab, 4x4, 6.2 gasser. I say we should look at 5ths that are 10,000 or below. He says we can go higher.
I've towed both. My old TT with a Chevy 6.0L gasser then my current Ram with 6.7L Cummins and then later a 5th wheel with the Cummins.
There are definitely advantages to both types of trailers. Hitching up a TT isn't a big deal. Some say it is and that's why they go with a 5er, but I never really had a problem with it. 5er's are pretty easy to hitch up but a mirror or camera certainly helps. The biggest difference is turning and steering. Neither is bad or good, just different when it comes to taking corners and backing into camping spots. One other thing is TT's can tend to be lower and easier to get in and out. 5er's tend to be taller and have more steps both into the trailer and also into the front bed area.
As others have said, your F350 is rated for 12,000lbs at least. That's fine, but I see your location is Northern California which means some decent hills, valleys, and elevation changes. Because of that, I'd say you stay under that 12,000lbs range for your truck. Sure, it's
RATED for that or more, but climbing steep inclines will make that gas motor scream. Yes, that engine is built to rev and will do it well for a long time, but I can tell you when I had my Chevy, listening to that engine rev at 4,000RPM as I pulled up long hills got very tiring. There is absolutely nothing wrong with towing up to the engineering limits of the vehicle but hearing the engine rev for long periods of time can get old pretty quick.
