4X4Dodger
Feb 27, 2015Explorer II
Lynnmor wrote:CavemanCharlie wrote:
I read an article in Trailer Life magazine that said if you are going to add shocks you need to get the angle right. If you do not then they do not help as much.
I read that article. The Monroe shocks are plenty strong, if I would have mounted them nearly vertical, they would have been too stiff. The more angle, the less they travel, so you need to make your best guess on how to set them up. If they are leaned too far, some shocks won't purge the air or gas from the piston area.
Hi that looks like a great job and I have a couple of questions:
Did you design and make the metal parts that are painted yellow yourself?
What is the function of that long bar running the span between the two shock systems along the length of the trailer?
How did you decide to size the section thickness of the material you used?
A great Job and I am sure it will work really well.
44,068 PostsLatest Activity: Jun 01, 2026
