Lynnmor
Feb 27, 2015Explorer II
Yes, I made the parts to install the shocks. The long bar allowed me to locate the upper shock mount where I wanted it, and also spread the load between all three spring hangers. My trailer has the incredibly weak "I-beam" that is made from three pieces of sheet metal welded together. The bar is made from square steel tubing with 3/16" wall thickness.
A side benefit is that the lower shock mount can accommodate a longer shock and is used as a jack point.
44,068 PostsLatest Activity: Jun 01, 2026
