mkirsch
Oct 12, 2016Nomad II
I don't think you're going to be much happier with that old F350 if your problem with the current truck is power.
What exactly is the issue with the current truck that makes it pull "like garbage?" Maybe we can address that.
Where did you get the info that said your truck was rated to tow 10,000? My 2015 Silverado daily driver is only rated to tow 6200 per the owner's manual.
Tow rating depends on engine, transmission, and axle ratio. Mine came with the 3.08 axle ratio, and it seems like most trucks had that ratio. To tow 10,000 with this year truck you need the 3.73 axle ratio.
44,056 PostsLatest Activity: Nov 19, 2013
