- Cummins12V98Explorer IIIHeck I am over 6' and i use the BenK method. The reason is I don't want to wear the edge of the leather seats by sliding in and out.
- Dog_FolksExplorer
MaxnSamsmom wrote:
I am SO glad I posted here - not only have I had some very good suggestions but I've also had some great laughs from the suggestions this morning!
Juts asked my wife, whom is 5"1"" tall. She drives our 3500 more than I do.(Because she is the better driver!) She says that with running boards, she has had no problems.
She said:"You just have to get over the fact that the truck is not a car."
I think she meant that unlike a car where you slide DOWN into it, with the truck, you enter standing up.
We both use the method that Benk outlined on page one. Works well. - MaxnSamsmomExplorerI am SO glad I posted here - not only have I had some very good suggestions but I've also had some great laughs from the suggestions this morning!
- danojenoExplorer
1oldtruck wrote:
Take a look at the AMP Research Power Steps. They drop when the door opens and raise when the door closes. They hang lower than a dealer installed step. They are a bit pricey at around $1,000. What's a another $1,000 when you already have so much invested.
X2. We have had them for about 4 years and they work great. They drop really low and shorter folks have no problem getting in. - alboyExplorerJust Picked myself off the floor ,now a aching gut, Too Funny!!!
- 45RicochetExplorerDang that Ram ain't that tall Troy. Those Blackies climb 200' trees around here though which is fun to watch. My darn dog will tree two at a time and keep running from tree to tree when they try to escape. Really good until the sow comes back into the picture :W
45Ricochet wrote:
Just joking OP but it might make your exit a bit softer :B
More joking... As the exit is not pretty.- 45RicochetExplorer
Just joking OP but it might make your exit a bit softer :B - PowerdudeExplorerYou could Redneck Bubbah it and put a set of running boards on the truck, and another set of running boards screwed into the "upper" running boards.
Make sure you put some lights on dem things, and a HUGE exhaust stack that goes higher than that 5th wheel too.
Add some mud guards that hang down real low to the ground too, with a couple of BIG knockers on them. :E
That would make the truck a real truck !! - rhagfoExplorer III
goducks10 wrote:
What were you thinking when you bought it?
He was thinking correctly the correct tool for the correct job, he is pulling a 5er, likely larger as he did get a 3500.
Then again, why not slam that 3500, lower it right down to the ground, solve getting in and the bed height issues. :B
Seriously the retracting running boards look great, but pricy.
44,043 PostsLatest Activity: Jul 24, 2025
