agesilaus wrote:
No, you need a HD/SD truck either 3/4 ton or one ton. The price difference between 3/4 and 1 is only a few hundred dollars so you may as well get a one ton.
If you are going to stick to the flatlands then a gas engine may work for you, otherwise get a diesel.
And do not listen to the 5ver salesmen on what kind of truck you need, they lie a lot. They'll say anything to get a unit sold.
BK
Ditto the above.
A salesman will tell you a Toyota will do just fine.....it towed the Space Shuttle to the museum in CA .....and he/she *knows* - 'cause he/she camped on the space station.:R
