49ford
Sep 23, 2017Explorer
Slide and furnace problems
I'm a newbie Rv'r. We have a 08 Keystone Passport Ultra Lite 285. We used it a yr ago and everything except outside grill worked. We tried it a week ago and the slide won't work, the furnace won't work.
So far, on the furnace. I have two full propane tanks, the water heater works, inside and outside grill works.
On the slide, I have a good battery charged to 13.5V, I have manually moved the slide out partially so its not stuck. I pulled the switch out and it has 12.5V from blk to red wires. I checked circuit breakers in front behind battery and cleaned terminals and continuity. Good, but one had seized nut and connector, so I have two new cb's coming. I tested slide by jumping and didn't move. I have checked every fuse, flipped every breaker two or three times. I think everything else in the unit works including AC. Does anyone have any ideas?
thanks
thanks
