Slide should be wired directly to battery with 30A fuse.
Not thru Fused Panel
Positive wire to slide is shorting out when rig is in motion....\ surprised it doesn't blow fuse when stationary---positive wire should still be making contact/shorting
If you can not ID slide positive wire at battery and follow if to switch then might be best to drag it that 100 miles for warranty work (which will take weeks/months and 'Gee it works fine").
Maybe you can contact RV MFG ----talk with service head guy and get Mobile RV Repairman authorization (you pay for 'service fee')
That way 'they' come to you and you get to watch/discuss problem
