I'll check and see if I can find any evidence of sparking on the red and white leads. I may be able to find some shrink tubing that I can put over the bare ends and see if I can get it shrunk down. The switch is about 30 inches in front of the slide fuse and 5 feet above it. I guess in an emergency I could run a wire thru the living space to the switch. So far this incidental grounding has never happen while stopped. So, I kinda thought if the fuse was pulled during tow times then there should be no shorting out, if there is no voltage on the wire. Only problem is, this fuse is at the very bottom of the fuses and the cover makes it awkward to get at. But I can relieve the cover to allow easier access. Think I'll see what a dealer says about fixing it, before hauling it to them. Thanks for the help, advice, info. Feel like I learned a bunch.
