ScottG
Apr 10, 2015Nomad
Actually, those adjustments you found will raise or lower the inside front edge of the slide as well.
You need to lower the slide at the outer most adjustment. This causes the slide to tip upwards at the front edge when it's in. Kind of a teeter-totter effect.
You may or may not have enough adjustment to clear the new floor. All you can do is try!
If this doesn't work then there's a much more complicated plan "B" (That I had to use) that involves adding rollers.
