Duane4238
Apr 01, 2018Explorer
Slide opens unevenly
Springdale 311RE. My large slide operates as it should, but when it reaches the open position and the slide motor clicks-ratchets and I release the switch, one side of the slide is open all the way and against the rubber seal. The other end of the slide is about an inch away from the rubber seal. I tried to push the end that's open the last inch or so, but I don't have the strength to move it. Is there an adjustment that should be made or perhaps a way to mechanically open that side the last inch or so?
Duane
Duane
