aztecaaExplorerOct 05, 2013Slide out supports!2008 Jayco with 2 slide-outs. Are there suppose to be supports under the slide-outs? If so can I make some or is it easier to buy them? Thanks
dodge_guyExplorer IIOct 06, 2013The other problem with them is that if you are on dirt/sand and use supports, when the trailer settles (and it will) the slide out supports will not, resulting in damage. do not use them!
