aztecaaExplorerOct 05, 2013Slide out supports!2008 Jayco with 2 slide-outs. Are there suppose to be supports under the slide-outs? If so can I make some or is it easier to buy them? Thanks
Doug33ExplorerOct 06, 2013You will see them on permanent sites from time to time, but only if the whole frame is jacked up on blocks. Even then, a majority of TTs on seasonal sites do not have supports under the slides.
