Harleybullet's avatar
Harleybullet
Slide problem
My AF 1150 slide does not go in all the way. When looking at the slide the upper front corner remains out about 3 inches and the top of the slide is out at that corner and tapers back to almost closed in the rear
Any ideas on a fix before I bring it to someone I can find who can actually fix it.... not much confidence in people fixing this.
Tried making it level with jacks and running it in and out.. no luck
Dave
  • Many moon ago, our 2000 AF 1150 slide started to sag. Factory said drive to LaGrand and we will fix it for nothing. We did...and they did. That was in 2002 and perhaps the AF culture has changed, but why not call and talk to upper management and see if they can help.
  • Our AF 1150 slide issues continued from almost the date of purchase. They ended for us when we sold the camper.
    I would suggest you contact Arctic Fox but that would be a waste of time.
  • Does one side of the slide tend to lag behind and then start moving?
    If so then you may have broken a shear bolt.
  • https://liveworkdream.com/2015/10/28/slideout-rails-adjustment/
    This should help.
