38-72
Jun 22, 2013Explorer
Slide stops and then starts up again
I’ve got a 2003 Artic Fox 5th wheel with a slide problem.
The slide goes out just fine. But, when retracting, it will come in about 8 inches or so and then stop.
If I let up on the switch for about 3 to 5 seconds, the slide comes in all the way without any problem.
I disconnected the motor from the slide gear rod and motor works fine under no load. I put a wrench to the slide without the motor attached and it comes in OK. I greased everything I could lube, but that didn’t change anything.
Does anyone have a suggestion as to what is causing the slide to stop and then go after I jog the switch? Could the motor be starting to go out?
