bobsbbq's avatar
bobsbbq
Small Gas Leak in Water Heater. Where could it be?
I have an atwood water heater, and occasionally I can smell a light propane smell inside the water heater and sometimes in the trailer. Since it has been much colder it seems to be worse but could be a coincidence. I have used liquid leak detector on all connections from the tanks all the way to the appliances and I have found no leaks. I checked in and around on the regulator on the water heater but did not find anything.
I think I remember someone talking about the water heater regulator leaking or a weap hole or something. Where can I or how do I test these places? Do you have to remove the tube attached to the regulator etc?
Any help is appreciated.
