Super_Dave's avatar
Super_Dave
Smarty Jr.
Since there was another thread regarding tuners it inspired me to write about mine. I have a Smarty Jr. and have installed the program #2, the tow/haul program. This program is supposed to add approx. 75 HP. I don't know if I was expecting too much but I honestly can't feel any of that in the seat of my pants either loaded or unloaded. Since HP ratings are always listed at unrealistic RPM's, I don't know if this is the reason I'm not feeling it or not. Do others of you notice seat of the pants differences?
  • Everytime I do an upgrade to my oil burner I watch the fuel gauge. DSo far I've been getting better and better mileage. Heck with the power, Diesel is expensive.
  • Same setting I use and I can easily feel it. Are all the setting at their default values? If the POD is adjusted down it will directly effect power output.
    Also, if you don't have a boost elbow, it would be helpful.
    BTW, regardless of what MADs says, you need a pyro. You absolutley CAN get the EGT's too high if your working the truck hard, like pulling a trailer up a steep mountain pass.
    I speak from experience.
    All settings are default. I no clue what POD or boost elbow is.
  • Just asking a question.
    Is your smarty updated
    Have you talked to Brian or Adam at Madd (smarty) 1-855-456-7627
    All I know from stock to SW2 there a big change of power and torque
    I ABSOLUTELY AGREE WITH SCOT.
    If I did not monitor my egt`s while towing my 14k 5`er, I would have lost my 5.9 MANY years ago.
    If you are concerned about high EGT`s try water/ meth injection.
    That said you still need boost and egt gauges with the SMARTY on SW2 or 3 when towing.
    Scot is spot-on!
  • We’re running a jr. on our 07 - 6.7.....and the performance change is very noticeable. How many horses, no idea....but pretty substantial. When you consider a truck that weighs-in at 7 or 8 thousand pounds, an 75 additional hp, isn’t going to “set your hair on fire”!
  • I went out and did some pedal to the floor tests and it was a lot more responsive.
