richy2 wrote:
Approximately three years ago I bought into the hype about Maxxis tires and purchased a set. The tires were made in 2012.
Upon pulling into a campground recently, I noticed a damaged tire, a section of tread was missing and steel belt exposed. The tire was fully inflated and I did not notice any difference in handling, there are about 15,000 miles on the tires and I drive 55 to 60 mph most of the time.
My wife noticed a popping sound about two hours before reaching our destination for the evening. Looking back it was probably the tire losing a portion of the tread. The best thing I can say about the tire is I was able to drive about 85 miles without it disintegrating and causing a lot of damage.
Since this event, I did a little research and found that trailer tires have a mileage expectancy of 12 to 15 thousand miles and should be replaced in three to five years.
I know there will be those that have had tires that exceeded these parameters, but my own experience in twenty years of towing seems to confirm these recommendations.
I don't know what you hit or when you hit it, but to drive 85 miles after a chunk of tire is missing takes a pretty good tire. Most will disintegrate soon after losing a chunk. If you don't trust the tires now, just replace them all. No worries, no hard feelings.
