My size is the 225 75 15 (D rated) and the max load is 2540 lbs. My camper gross weight is 11k so I would like more wiggle room than that.
Lynnmor wrote:
bmet2000 wrote:
So if the answer is switch to LT, please tell me what LT 15" tire I can put on my camper as there doesn't appear to have room for a 16".
So what is the current size? I had ST205/75-15 China Bombs that I sold on C-list and replaced with USA made Goodyear Wrangler HT's, size LT215/75-15. I also replaced the steel wheels with 6" wide aluminum wheels. The tires are about .7" taller and just a bit wider so there was still enough of clearance. That makes the tire .35" closer to the trailer body and .7" less between the tires.
