Hi,
I have a E-meter in my motorhome, so I can track how many amp hours I use in a day. Running just the refrigerator, CO and propane leak detectors will use up about 35 amp hours per day. Add to this about 1 amp hour per light per hour, 4 amps to run a TV set, 2 amps to run a computer through a inverter per hour, and you can get a idea of what size system you will need.
A single 120 watt solar panel will make up about 35 amp hours per day and take care of the "House" load. Then add a second panel to take care of lights, 2 hours of TV or computer use. If you want to run the furnace a lot, it can use 6-7 amps per hour, or 35 amp hours during a cool winter day - with the heater set to about 60F overnight.
What I use is a Olympic Catalytic safety heater. 6,000 Btu's will heat my 30' motorhome to about 70F inside when it is above 32F outside. Below that temperature, I will need to run the furnace to re-distribute the heat and also warm the bedroom, and keep it at 70F. But I only need to run the furnace about 1 hour per day.
The water pump uses a in-significant amount of power. While it will draw 7 amps per hour, it also pumps 2 gallons per minute, or 120 gallons while using only 7 amp hours. So if you only have a 60 gallon tank, then it will only use 3 amp hours to pump it dry or less than 1 amp hour per day.
So my suggestion is looking at this website.
SunElec.com and look for 12 volt nominal solar panels, and a 10 - 30 amp PWM controller. Check the size of the 85 to100 and 150 watt panels (length and width). Then go up on the RV and see what will fit around the A/C and roof vents, antenna, and other things up there. You might need to buy one 100 watt for between the shower skylight and edge of the roof, and a another size for someplace else.
While it is "Nice" to have or 4 panels the same size, it is not required.
For wiring, I used #10-2 UV resistant grey wire, Home Depot.
FOr panel mounts, I cut 6" long 2" angle aluminum channel, and drilled 3 holes 3/16" for the roof side and #10 screws into the roof (with lots of roof sealant to keep it in place and dry under it. 1 hole 5/16" to a hole into the solar panel.
I mounted my controller in the bedroom closet, and ran the wiring behind the refrigerator vent.
Good luck,
Fred.
