Hi,
Yes take measurements of the roof. If you find a great deal on a 230 watt model that is 48" wide and 75" long, it probably will not fit anyplace on your roof without going over a vent or something. I have a pair of 39" X 60" panels on my roof, they are only 120 watts, that is about the maximum size I would recommend. Lay them out in cardboard first, making sure they will not get shaded by the antenna or A/C or something.
It is best to have them mounted 1" above the roof, the air circulating under them will cool them, and they produce more power when cooler.
I used 2" angle aluminum from Home Depot, 6" long to make brackets for the 4 corners. Ran the power lines down the back of the refrigerator to the controller. Use UV rated grey romex, rated for direct burial works fine (Home Depot).
You want to look for 12 volt panels with nominal out out of around 19 - 21 volts "Open circuit".
Look for a PWM controller rated for 10 - 20 amps.
You can use multible controllers for one battery bank, they will all try to keep the battery full, and will all shut off once you reach 13.8 volts.
This place has a great price on solar panels.
SunElec.comYou can look for the balance of the system there or from many other places. I bought my solar panels from this place back in 1999.
SolarOnSale.comI found out about solar systems from this magazine.
HomePower.comFred.
