valhalla360 wrote:
Pull a truck camper...first, there is no place to latch on and pull but even if you did, the jacks will likly rip off and then it will be dragging on it's bottom. A couple hundred feet and it may be a total loss.
Obviously, you haven’t seen a truck camper move on the jacks. Trust me, they can. If you have forks, you could easily lift it from underneath. That’s the way they take them off trailers. I’m not sure why you’d want to move one a couple hundred feet.
westernrvparkowner wrote:
Giving the reason or explanation for any rule or policy is a fool's errand. It took exactly two posts from the time so one gave the published reasoning behind a policy before someone chimed in with their own conflicting theory. Mom actually had the best reason ever when questioning a rule. That answer was "Because I said so".
Giving a fake reason is no reason at all. It’s easy to point out why you were wrong. In that respect, your Mom was right. Don’t make things up to try to justify a park’s reasoning just say there is no reason other than that’s what they want to do.
Full circle, there isn’t a justification other than that’s what the park wants to do, but that’s ok.
