pcoplin wrote:
AISURFFISH wrote:
This response is without a doubt the most insulting and at the same time aggravating post I have read in quite some time..
The original poster is asking a specific request for help.
So let's help this guy !!!
Not all of us can just jump under a truck and start wrenching.. I'm only 41 and will ask for help or spend a few bucks to have a HARD part installed.. I can only imagine a retired person or even a disabled person needing help on the road...
As an employee of a local government agency I work every day making the world more accesable via ADA requirements..
EVERYONE HAS DIFFERENT ABILITIES!
I didn't mean any offense. I was just trying to convey it's an easy install if the hole is drilled. If you can't lay down on your back, that would be a disability issue. I should have worded it wrong. If you are physically able to do it, I's personally recommend doing it instead of spending the money.
If you take offense to that, I apologize. And I'd also recommend you take some supplements to grow some slightly thicker skin.
^ Now that hat last sentence could be considered aggravating. :)
Its thick enough to call you out!
I aint skeered ...
