Happy_Camper_34's avatar
May 30, 2014
Suburban 6 gal. gas/elec wh ?
My wh will work on elec ok but never gets much beyond luke warm. I want to use it on gas in order to reduce my amp load. When I use it on gas it does basically the same thing. It was running on gas for a short time then acting like someone was gradually turning the gas off until it got down to burning at the orfice then it went out. I replaced the gas valve/coil assembly this past weekend and that seems to have cured that problem but it is still not making hot water. Do I have a bad board? Where is the thermostat? Is it bad?
  • Thank you both. Just 1/4 turn of the mixing valve and wa lah, hot water. I already had a design in mind to mount a portable Rinnai V53 tankless wh on the back bumber of my camper. It was going to be very simple to connect and disconnect. Still may do it one day :) Not that much more money to do it either vs. a new 6 or 10 gal. rv unit.
  • Hot/cold water mixing via water heater 'bypass valve' being partially open is common luke warm water problem.
    Also turning shower(s) off via handle vs closing hot/cold water knobs will also allow hot/cold to mix making luke warm water
    IF water coming out of Pressure/Temperature Relief Valve is hot then check bypass/shower valves. (Press/Temp Valve is in outside compartment and can be opened via lever....caution water could be very hot and will spray)
    IF the water is not hot (Press/Temp Valve).......then check that t-stats are tight and have clean connections.
    The t-stats are in outside compartment under the black rubber cover above gas valve and have 'Push to reset' on them.
    Under that cover are 2 sets of t-stats
    Left ones are 120V AC normal (bottom) and high temp (top) for electric element
    Right ones are 12V DC normal (bottom) and high temp (top) for gas valve.
    Luke warm water on both electric and gs sounds like a valving problem not t-stats
