canoe_on_top
Oct 12, 2021Explorer
Suburban heaters unually have a switch on the unit that can be turned off so that if you accidently turn on the switch inside when the unit is empty it won't burn out the electric element. In everyone that I have seem, there is, also, an electric switch inside. As mentioned, there's a separate switch for the propane heater.
