RedRocket204
Oct 14, 2016Explorer
I had slide power problems on my TT, meaning also no power, unrelated brand. Turned out my issue was a fouled ground connection of the slide switch. The slide switch ground was connected to the frame directly below where the switch was. I was able to locate the fouled ground by systematically working backwards from the batteries testing all points independently on the 12V + wiring while using the frame as a separate ground. Then ultimately found that the ground used for the slide switch was fouled and needed to be removed, cleaned, greased and tightened. No problems since then.
Just a FYI for something to look into.
44,029 PostsLatest Activity: Jan 28, 2025
