Cecilt wrote:
JIMNLIN wrote:
I have them on my 3rd gen '03 2500 Dodge/Cummins. They work great.
For some reason Dodge dropped the aux upper overload spring pack from the 3rd gen trucks. My 2wd truck needs help with anything over 1500 lbs.
I don't have the upper overload spring on my truck either. ARe you using the 1 or 2 leaf super springs set. tks
Mine were the two leaf 5k set which in '03 was the only option on my Dodge if I remember right.
My Supersprings didn't raise the back of my truck and still have a OEM ride when empty. I've replaced the rubbers twice at no cost to me.
My 11200 lb 5er adds around 2100-2300 lbs to the trucks rear axle.
I also pull a 16K tri axle GN stock trailer. With the Supersprings I can now load the trucks rear OEM tires to their limit without the headlight tree topping.
