Grit_dog
Jun 07, 2013Trailblazer
So camper is 1500 lbs dry, you'll be over 2000lbs total.
Start by having some good LT tires on the truck. D or E rated 3k+ lbs per tire.
Good shocks on the truck as well.
Airbags are the premium solution since you can adjust the support infinitely to your load/ preference.
Add a leaf or bolt on overloads are sufficient and the cheapest route.
Timbrens are IMO the best compromise between ease of install and cost and they will hold that load up sufficiently as well.
44,068 PostsLatest Activity: Apr 17, 2021
