jornvango's avatar
jornvango
Explorer II
Mar 31, 2017
Taking the camper off the truck
If there is 1 thing about owning a truck camper that intimidates me (even after 3+ years), is taking the thing off the truck. Those camper legs can support 2000 Lbs each (which means 1 leg can support our entire camper as that is the camper's weight) but they look so skinny that it's stressful to raise the camper to the needed height so the truck can drive underneath ...
Our camper is light without slides or overhang in the back so I assume the process of loading/unloading the camper can be even scarier if you have a bigger truck camper.
Other than making sure that the front of the camper is always a little higher than the back, are there any tricks that will loading/unloading less scary?
E.g. what about high winds when the camper seems to rock back and forth when sitting up high on the legs ...
Thanks!
