- RoyJExplorer
time2roll wrote:
RoyJ wrote:
Correct. C/5 would be drained over 5 hours
That is one very fast Semi to drain the 600 mile range battery in one hour...
OK climbing a hill or even accelerating could well be at the 1C rate for a short time. Although I believe this is all within design specification as long as the battery is kept within proper temperature range.
Where did I mention a semi drained the batt in 1 hour?
I specifically said high duty cycle applications are designed for C/5 to C/10 drain rates. Reisender wrote:
Rivian at up to 180 is the largest I know in a planned consumer vehicle.
I would think most SUV’s won’t see batteries bigger than 100 - 120 KWh and even vehicles like Cybertruck and Hummer won’t go much above 220-240 KWH. When they start to shoot for the 3/4 ton or 1 ton market that might change someday but I haven’t seen anything like that on the drawing board yet.RoyJ wrote:
OK climbing a hill or even accelerating could well be at the 1C rate for a short time. Although I believe this is all within design specification as long as the battery is kept within proper temperature range.RoyJ wrote:
My concern is the speed at which the pack is drained - nearly 1C. This is very hard on a big battery pack.
Batteries from lead acid to lithium are used in plenty of heavy duty applications, but they're sized for closer to C/4 to C/12 rates.
That's why I mentioned 1000 kWh - at that size, we could tow a regular commercial travel trailer and maintain say, a C/5 rate of discharge. Ideally you'd arrive at a campsite and charge overnight at C/10 rate. Not being blasted by a supercharger at 1C+
So far semi regular supercharging hasn’t had a big affect on Tesla batteries. Having said that most charging is fine at home sooooo...
I would think most SUV’s won’t see batteries bigger than 100 - 120 KWh and even vehicles like Cybertruck and Hummer won’t go much above 220-240 KWH. When they start to shoot for the 3/4 ton or 1 ton market that might change someday but I haven’t seen anything like that on the drawing board yet.- RoyJExplorerCorrect. C/5 would be drained over 5 hours
- 1C? Is that drained in one hour?
- RoyJExplorerMy concern is the speed at which the pack is drained - nearly 1C. This is very hard on a big battery pack.
That's why I mentioned 1000 kWh - at that size, we could tow a regular commercial travel trailer and maintain say, a C/5 rate of discharge. Ideally you'd arrive at a campsite and charge overnight at C/10 rate. Not being blasted by a supercharger at 1C+ - GrooverExplorer II
RoyJ wrote:
This hasn't been mentioned yet - but wonder if constant heavy discharge, followed by fast charging, will take a toll on battery life. Much more so than an IC engine running high duty cycle.
I'm far from anti-EV, in fact, I believe 99% (not an exaggeration) of commuting should be done with EVs.
But the fact is battery technology is not quite there yet to support heavy duty-cycle. The motors are, and have been ever since GM introduced the first diesel-electric locomotive. 99.9% of rail freight use electric motors for motive, the <.1% being heritage steamers.
As soon as we have reliable 1,000 kwh battery packs, with negligible Peukert factor, then bye-bye ICs.
It does, more so near fully charged or discharged. However, most users have home chargers that do overnight charging and I suspect that many commercial uses will do the same. Tesla seems to be less affected than other brands by battery degradation and is working hard on "million mile" batteries. That would probably mean around 80% of new capacity at one million miles. That is a lot of miles, even for a commercial vehicle. Speculation is that they are already there and are just saving the announcement to make the battery day presentation more exciting.
We should know in about 8 weeks. - thomas201ExplorerBe careful driving that beautiful rig above. No ground clearance. A humped RR crossing will high center you for sure. Ouch!
It’s a good question and I don’t know the answer. But judging by the amount of busses, mining equipment and grid storage being built I would think that at least some heavy duty deep cycling is supported.
There will be new info coming on Tesla’s battery day in September. Might be interesting.
44,066 PostsLatest Activity: Mar 14, 2015
