They will work and a lot of people have done it… the wiring may be a little different and you may need to add a switch to have hi and lo fan speeds…
I installer the hunter programmable one, but found it to be unreliable… after replacing it several times I went back to the overpriced Coleman manual one several years ago… I had to replace it again a few weeks ago, but was glad it was the overpriced t-stat this time… if it wasn’t the T-stat the only other thing would have been the very overpriced and non-repairable relay module in the AC…
