Changing the t-stat to a digital one is usually the first mod I do to any RV I got. The manual t-stats have a 2-4 degree swing high and low. A digital has 1-2 degree swing. It is very easy to change out. I have usually used the Walmart Hunter t-stat and never had a problem. You can get the tiny switch from Radio Shack to make the fan high and low also, but some folks just let it on high. Here's a couple of sites to cut and paste that give you instructions on how to do it.
http://www.klenger.net/RVing/HVAC_Hunter_Tstat/hunter-digital-tstat-instructions.pdf
http://www.modmyrv.com/2008/07/14/rv-digital-thermostat
http://home.roadrunner.com/~morodat/hunter_install.html
