Grit_dog
Apr 04, 2020Trailblazer
Don’t get too wrapped around the wheel (no pun intended) about having a Mac daddy tire changing setup.
Unless you’re rock crawling or a bad driver, you shouldn’t expect to be getting flat tires often. IE I wouldn’t buy an expensive impact just for changing flats. If you have a regular use for one and have it available, it’s convienet.
And if you have a generator, skip the Viaair unless you have a tank to store some air. Otherwise it’s only good for tires and air bags.
Space is a concern so don’t plan on blowing out water lines on the road. If you need air for water lines, just flip a service station $5 to use some air for a few minutes.
I can’t even think where I’d store a suitable compressor for that with a TC.
44,066 PostsLatest Activity: Oct 04, 2013
