mike_brez
Jul 15, 2014Explorer
Tire blow out trailer
My buddy just sent me these on the way to Va. From Ct. Trailer is under one year old.
Click For Full-Size Image.
ReneeG wrote:wmoses wrote:ReneeG wrote:
Couple of things here. We had a blowout on our fifth wheel recently and we have a TPMS system. No warning and I had just looked at the screen, when boom!
Just a little bit of a tangent here since I am in the market for a TPMS - can you tell me what brand / model you have?
TST Systems.
Me Again wrote:CKNSLS wrote:
The trailer is not 1 year old and the tire may have been overloaded. Westlake now has the nylon cap like the Mx brand.
Tell me why the magic Nylon cap has not made the GY Marathon the top of the line of ST tires? We are talking about a major tire company that added the Nylon cap to the Marathon in the late 90's!
Maybe it is all about tire weight and the related construction. Look at the Mx brand weight compared to the other ST tires.
1. Michelin XPS RIB LT235/85R16 LRE (rated to 3042lbs) Weight 55.41
2. Goodyear G614 LT235/85R16 LRG (rated to 3750lbs) Weight 57.5
3. Bridgestone Duravis R250 LT235/85R16 LRE(rated to 3042lbs) Weight 60
4. BFG Commercial TA LT235/85R16 LRE(rated to 3042lbs) Weight 44.44
5. Uniroyal Laredo HD/H LT235/85R16 LRE(rated to 3042lbs) Weight 44.44
6. GY Marathon ST235/80R16 LRE(rated to 3420lbs) Weight 35.4
7. Maxxis ST235/80R16 LRD 3000 lb rating at 65 lbs of air weights 38.58
8. Maxxis ST235/80R16 LRE 3420 lb rating at 80 lbs of air weights 43.43
9. Duro 2100 ST235/80R16 LRE 3520 rating at 85 lbs of air weights 35.5
10. TowMax ST235/80R16 LRE 3420 lb rating at 80 of air weighs 35
LarryJM wrote:Huntindog wrote:ReneeG wrote:
The sidewalls are meant to take the turning and flexing that towables are subject too that LT's can't handle
Who told you that LTs can't handle it?
I have never read that ANYWHERE. An awful lot of high end TTs come with LTs, and many of us have upgraded to them....
The ad propaganda from the ST tire makers are/is careful in their wording around this subject.... They NEVER state that LTs can't handle it.... They do imply that ST tires are especially good at it.
That doesn't mean that LTs fall short of the job.
Big difference.
I often wonder how overtired some of these TTs that have LT tires are and if that compensates for the resistance to the flex and scrubbing issue. In other words how would a side to side comparision of say an LT tire with the same load capacity as an ST tire do on the same trailer.
Larry
fla-gypsy wrote:
If you have the space and wheel size for LT tires they are an alternative. If you don't there are better choices in ST tires that can be very successfully used. I have used ST tires since 1998 with great results.
Big difference.
Keith Haw wrote:It is only obvious if you are of the belief that it can't be any better.2oldman wrote:Huntindog wrote:I don't know, I would think the point would be obvious. Guess not.2oldman wrote:And the point is?
Most vehicles/trucks don't weigh as much as a loaded RV.
Yep, me to.
2oldman wrote:JohnnyG73 wrote:Most vehicles/trucks don't weigh as much as a loaded RV.
Like I said, why should I have to expect less from a trailer tire when it travels the same road as the TV.
