Campin_LI's avatar
Campin_LI
Tire Pressure - but wait... a different question!
This came up at work. Thought I would post to see what others thought.
When setting the tire pressure, do you set it when the truck is loaded or when it is empty.
I'm assuming empty but a co-worker says the pressure in the tires will be higher after it is loaded (if you pump tires to max psi, they will be over max psi and then when they heat up they will be way over). He is probably right but is it a negligible difference, anyone know?
With the airbags on my truck, I set them at 10 psi when unloaded and once loaded they are at 20 psi. I know airbags are not tires but the same logic applies.
