- chracatoaExplorerSo the front right tire doesn't register anymore even with the repeater. I tried to reprogram it and it didn't work. I think the battery is dead. It's brand new, I'm contacting TST - maybe all the batteries are bad.
- Heap64ExplorerI just installed the 507 with internal sensors on a 30' travel trailer. It wouldn't pickup the sensors until I added the repeater. Now it works great. So far I just did a temporary install with it in the front pass-through storage area. I plan to wire it into one of the storage lights to pickup power and keep it inside.
- Ron3rdExplorer III
chracatoa wrote:
Receiver is on the windshield. I noticed that it had 1 tire already programmed in it when I started working on it. Maybe it was a return and the batteries are not good?
I would try a new battery before buying the repeater. I bought 10 of the batteries off Amazon for $7.55 with free shipping.
I would think if the receiver is up on the windshield, it should work with that length trailer. As mentioned, I have a 35ft TT and have no problems. Mines on the dash in that recess where the clock is. It just sits there on the provided base - MARKW8Explorer
I was told by them that they program one tire to check function. Then don't do a delete.
Mark - chracatoaExplorerReceiver is on the windshield. I noticed that it had 1 tire already programmed in it when I started working on it. Maybe it was a return and the batteries are not good?
- MARKW8Explorer
Ron3rd wrote:
MARKW8 wrote:
I'm surprised your having that problem. I have the TST 507 with a 36' 5er and a CC long bed. I've had no problems at all without a repeater.
Mark
X2, I've got the same system as the OP and a 35 ft trailer, moving from a 25 footer. I had the same problem as the OP when I went to the longer trailer but moved my TST receiver up on the dash by the clock and the problem disappeared. Where is your receiver mounted?
Mine is usually on the dash top during travel.
Mark - Ron3rdExplorer III
Mark
X2, I've got the same system as the OP and a 35 ft trailer, moving from a 25 footer. I had the same problem as the OP when I went to the longer trailer but moved my TST receiver up on the dash by the clock and the problem disappeared. Where is your receiver mounted? - MARKW8ExplorerI'm surprised your having that problem. I have the TST 507 with a 36' 5er and a CC long bed. I've had no problems at all without a repeater.
Mark - chracatoaExplorerI see, maybe I can mount it inside the battery box and let the switch hanging outside.
Also, I second lbrjet question... - lbrjetExplorer
WDP wrote:
The Tire Tracker TT-400C is the same unit, different box. The repeater is NOT waterproof and is to be mounted inside. I installed mine in a night stand with Velcro, out of the way and wired it to a reading light above the bed. Turn the light on when traveling and your drop outs are gone.
WDP
How did you get to the wires?
44,068 PostsLatest Activity: Jun 01, 2026
