Old-Biscuit wrote:
Tire Max Load Rating is same as or more then trailers axles.......
Remember-----
Trailer tongue weight is part of trailers GVWR BUT is not carried/supported by trailers axles/tires. Tongue weight goes on tow vehicle
SO YES tires are marginal but they cover the axle weight. Axles are probably rated at 3500# each for 7000# also.
Thanks for all of your responses. I had forgotten about the tongue weight. I will not intervene regarding his tires. I did tell him about the importance of keeping them pumped up and how heat will also be an issue. Of course driving fast creates more heat, so there you have it.
Thanks again.
