Hi,
I've been able to run the roof air since 2011--just not for as long as I would like (without a generator).
Keep the existing batteries and spend the money from the savings on LiFePo4 for solar panels, a much larger capacity charge controller, and a large inverter/charger (Victron?).
You may find that with enough solar the existing batteries will get you through a day.
The problem with a dc to DC for the alternator is duty cycle. If the alternator is 130 amps (as mine is), it may be designed for a 1/3 duty cycle--in other words, only about 43 amps. That is why I chose a dc to DC that maxes out at 20 amps--because they are HUNGRY on the input side and draw 30 amps to output 20 at a higher voltage. That gives me some head room for other electrical needs. As it is--my solar panels send energy to the engine, when the sun shines.
If you want to try larger--there is a 40 amp from renology that has a jumper that can be removed to drop it back to 20 amp.
The solution is to replace the alternator with one that is continuous duty, and/or have an external diode. The continuous duty is better (and costs a lot).
My own plan is now to do a massive upgrade to the solar (1400 watts fixed flat) and see how the existing battery bank reacts. The RV has been in storage for 18 months now.
