If you filled up or are currently connected to well water source, you may have iron in the water. I have to run my well water thru a softener with iron removing properties before filling my tank.
A rotten egg smell is common in rusty well water. The smell comes from non-disease-producing bacteria:E that feed off the iron. The smell also can be from sulfates in the water reacting to the magnesium anode rod in the water heater. High rust content can make the water taste metallic.
ColorIf there is no immediate color when you draw water from the tap, your rusty water contains dissolved iron or ferrous oxide. Contact with the air gives the water a rust color. If the tap water is reddish brown or yellow right away, then the iron is undissolved, or insoluble ferric oxide.
More Info
