CincyGus
May 08, 2019Explorer II
scbwr wrote:
Happy Camper works for us!
Happy Camper works well and no harsh chemicals. I've had pretty good results with Camco Rhino hoses but there are quite a hose systems that should work quite well. Just make sure you have 25' or more of hose if you plan to travel around.
I've used something just like the Rhino Blaster, but made by Valtera. The Rhino Blaster should be fine and I would suggest getting it with the gate valve.
X2 on the Happy camper and Rhino hose. My Rino Hose is 5+ years old and is as strong as the day I bought it. I've never used a Blaster in my black tank. Filled the tank before leaving the campsite and heading to the dump station and then dumped. Once it was empty, pulled out of the way and filled it again to 1/4 full for the trip home. Sloshing around on the ride home and having water in the tank when it sits waiting on the next tank has always kept mine clean. How do I know? Never had a clog, a smell problem or a tank sensor issue.
Tank Flushers other than a built in one's or a wand you stick down the toilet are in my opinion a "See the clean water coming out thru my clear elbow" Magic trick that proves nothing about if your tank is clean, only a few feet of your hose. Just my opinion but not without some test results to back it up.
Black Tank Rinsing Test
