mkirsch
Mar 01, 2016Nomad II
1964DeCamp wrote:
All great advice! thanks! It is a smaller SUV, the wheel base is smaller, so that may be an issue. I also don't believe I've ever had the tires at max pressure, so that's another thing I will try...Usually with the WDH it is pretty level, It's just a white 'knuckler trying to keep it steady when being passed or passing large trucks. I wouldn't say "squirrly" per-say, just difficult to keep it straight. It doesn't sway too much, except when passing... as I do have a sway bar (but I set it rather loosely) I'm new to towing anything except a pop-up, and that towed effortlessly with our mini-van. That being said, any advice helps, and I won't take offense, because I don't have a clue :)
One thing we need to do is clear up a few misconceptions:
1. Any true sway is too much sway, period. It's highly unlikely that you have any true sway though, because you'd be here reporting your accident, in the hospital recovering from your injuries, or dead. Sway is the trailer wagging back and forth, getting worse and worse until you apply the trailer brakes manually, or the trailer yanks you off into the ditch.
2. You do not set a sway bar "rather loosely." Sway bars are either on or off.
3. "Pretty level" is not how you set a WDH. There is a good FAQ at the top of this forum on setting up a WDH properly. You are looking to return the front ride height to where it was when the trailer was unhitched. Level is not relevant here.
To me it really sounds like you just need to learn a few things. Right now as you admitted you don't have a clue, and just set things up so they looked right to you.
44,060 PostsLatest Activity: Mar 28, 2026
