tbred's avatar
tbred
Explorer II
Aug 08, 2013
Tow /haul mode questions
Hello to all! Hoping to pick some brains and get some answers.
We recently traded our 2008 f250 6.4 (nothing but issues starting) for a new 2012 f250 6.2 (gas) understandably towing and torque is different but it seems abnormal that in tow/haul mode the trans would bypass 3rd and slam into 2nd on even the slightest grade. It would then sit in 2nd often revving well over 5000 rpm even upon leveling out. We finally finished the trip manually shifting, but lost the engine braking feature in doing so. Planning on taking it to Ford but I know they won't be able to duplicate this without towing. Any thoughts/experience? Thanks!
  • Your tranny may need to be reflashed. FWIW I had a 10 F150 5.4 6sp w/o the select shift feature. It would do the same thing going over overpasses. It would shift from 6th to 4th then to 5th until it went over the overpass. It always seemed to shift down one extra gear before finding the right one.
    I ended up fixing the situation with a 12 Ram CTD:)
    BTW how much weight are you towing?
  • My 2012 is the 6.7 diesel, but it does not even drop from OD on slight grades. And it smoothly downshifts on greater grades, never skipping a gear. I don't think what you are experiencing would be normal even for a gasser.
    I had an intermittent problem on a 2004 SD only while towing. So I hooked up an implement trailer with a tractor on it and went to the Ford dealer. He connected his portable diagnostic monitor and off we went. Problem showed up, he noted the problem, back to the dealer, replaced the EGR valve, back on the road within the hour. Maybe your service tech or manager would do the same.
