Hello, I wanted to get everyone's advice. I have a 19 foot Stellar Eclipse Toy Hauler. I hooked it up to my Armada and needed to go 10 miles so I hooked it up as is, but I think I may need to go up o...
Do this; measure the height from the ground to the lip of your FRONT fender BEFORE hitching. Then, after hitching everything up, measure the SAME spot. It should be close to the same measurement. An inch higher is OK, but NEVER lower. Moving up, or down a link at a time on the WD bars chains will set adjust it. Good luck, and be safe.
