- ADA6969ExplorerWow. I been driving for 10+ years 45k miles all over west cost with my old set up A/F 990 28" STINGER WITH 300-500 LBS OF Tongue weight. on a 7500lb trailer. The truck did not know it was towing anything neither did I.
- LwiddisExplorer II"trailer tows great with 400 lbs. of tongue"
How many panic stops have you experienced with this set up? Winds? Bad roads? - Homeless_by_ChoExplorer
ADA6969 wrote:
If the trailer tows great with 400 lbs. of tongue why do I need more?
Because under adverse road and wind conditions, the trailer front will bob up and down causing lack of control and traction.
LeRoy - ADA6969ExplorerIf the trailer tows great with 400 lbs. of tongue why do I need more?
- Homeless_by_ChoExplorerFor a gross trailer weight of 7500 pounds, the recommended tongue weight should be at least 750 pounds but not more that 1125 pounds. That kind of weight on a pickup truck with a 48” extension will make steering very difficult and may lift the front wheels off the ground when driving at highway speeds over real rough roads. I am guessing with the AF 1150, that the gross rear axle rating of your truck will be greatly exceeded. I certainly wouldn’t ever do that.
LeRoy
44,043 PostsLatest Activity: Jul 24, 2025
