ognend
Jan 10, 2021Explorer
Towing capacity vs max cargo weight rating
Hello all!
Can someone clarify something for me? If a truck's max gooseneck trailer loaded weight is 15,100 lbs (as per manufacturer towing guide - it is a Ford) - how can the max cargo weight rating be 1792 lbs?
If I understand correctly, the max cargo weight rating is all the weight that can be put into/onto the truck (passengers, their things) PLUS the, for example, weight of the gooseneck pin of the loaded, 15,100 lbs trailer.
Ford's towing guide says: "Cargo Weight Rating shown in chart is maximum allowable, assuming weight of a base vehicle with required camper option content and a 150-lb. passenger at each available seating position".
Does this mean the allowed payload is AFTER 5 passengers? if I removed 3 passengers, does that add 450 lbs to payload capacity (max allowed cargo weight as per Ford)?
In addition, what gooseneck trailer weighs 15,100 lbs (max loaded trailer weight spec as per Ford) but only 1792 on the hitch (as per max allowed cargo weight)? This would imply that only 12% of the loaded trailer weight is on the hitch. Does this sound right?
I know this is not the case for my loaded horse trailer with living quarters (but then horse trailers with living quarters tend to be front heavy).
Am I understanding this right?
Thanks!
Thanks!
