rbpru
Aug 22, 2016Explorer II
My C rated tires were 7 years old when I replaced them. They had the 15,000 miles I put on them plus what ever the previous owner had on them.
I chose D rated replacements because the load rating charts gave me some leeway on the tire pressure.
You can go with the factory suggested tires, upgrade the load rating or even switch from STs to LTs. None of this makes any difference when you run over a road hazard. If not caught immediately you will shred the tire.
I have had three flats while towing, one on the TT I caught as a leak while checking tire pressure and two on the TV. All three were punctures caused by a nail or similar road hazard. My truck has tpm built in which was handy. My TT does not but should, as a flat is less noticeable on a TT.
