maxwell11's avatar
maxwell11
Trailer Life Article - 5.9 Cummins engine
This months Trailer Life Magazine had a write up on the 5.9 Cummins engine, the write up covered at least 6 or 7 pages.
As I read the article all 5.9 Cummins engine block coolant plugs rust out. The article did not place our truck engines in a very good light.
I had the coolant changed in my 2005 dodge diesel truck at 5 year intervals with Dodge approved antifreeze and distilled water.
So far, I have had no problems with the cooling system. However, after reading the article I will keep a bit closer eye on the motor block freeze plugs.
Have any of you guys had problems with the freeze plugs rusting out and leaking coolant????
  • Antifreeze has a rust inhibit change at the recommended intervals and you will not have a problem.
  • My dad is around 230,000 on his 5.9. No signed of trouble at all. The only thing wrong with his ram is a few little cracks in the Dashboard.
    Cheers!
    Jeremiah
  • '07 5.9......water pump sprung a leak at 85,000 miles so I changed coolant and water pump at that time.
  • rhagfo's avatar
    rhagfo
    Explorer III
    fj12ryder wrote:
    No problems with my 2001 so far.
    Ditto and 270,000 miles.
  • I hang out on a couple of Cummins forums and have owned them for 21 years.
    Never heard of then rusting out.
    Sounds like somebody never changed it.
  • No
    But if you neglect the recommended service of 5 years or 100,000 miles (IIRC) you could very well have problems. I believe all manufactures have similar maintenance schedules.
    Maybe link us up to the article if you can. They are certainly not on my bookmark list :W
    Only on the unmaintained trucks. if you maintain your vehicle it should give no issues!
