Kylesmith3021's avatar
Sep 03, 2017
Trailer Lights
So first time this has ever happend to me...Brake lights and signal lights and r ways work on travel trailer however no running lights work on it...Truck lights are all working fine..I tried truck lights on auto then aux on and still no running trailer lights..I tow with a 2014 f150 ecoboost with a 7way plug..Not sure what to do since i am not savy with electrical things
  • its not that part its a actual plug in harness to factory plug then you wire those wires to the 7 way wires..unfortunetly theres not enough wire from harness to re wire
  • Kylesmith3021 wrote:
    so i found where the problem was but im not sure what to order...its a harness piece that plugs into truck under the bed by spare tire and goes to my 7 way for my truck...I noticed it has a couple of wires chewed up
    Available at many auto parts stores and trailer supply stores.
    Like this
  • so i found where the problem was but im not sure what to order...its a harness piece that plugs into truck under the bed by spare tire and goes to my 7 way for my truck...I noticed it has a couple of wires chewed up
    i pulled the fuses under the hood and checked them but nothing was blown
    Do you have a main fuse panel inside the truck? I'd suggest to break out the owner's manual and find where the fuse is for the trailer lights. That fuse, in my truck, is located in the main fuse panel beneath the dash. Yours may be in the kick panel or under the dash.
    If this is all too much for you, seek technical help.
    Looked it up: The fuse block is under the glove box, passenger side.
  • The first thing you need to know is whether the problem is in the truck or the trailer.
    To test this you will have to know about "electrical things." Since at a minimum you will need to use a multi meter or a test light I suggest you take your trailer to a shop and get it fixed. On face value it's going to be an easy fix so it should be cheap to fix.
  • Check for voltage at the contact in the truck receptacle. You can find the diagram at etrailer.com. If you have voltage, then the trailer is the problem and that often is a bad connection in the plug.
  • Look in your owners manual for fuse block and location of fuse within the fuse block. Use your test light to test fuse with the lights on. Test light should come on when touching both test points on the fuse. If you don't have a test light, go to NAPA, Auto Zone or almost any big parts store and ask for help testing a fuse.
  • on my 2005 f150 the fuse is on the passenger side fuse box. down buy your feet.
  • I had that problem once with a ford and there was a fuse in the fuse box under the hood was for trailer clearance lights.
